PC overheat, need help!
Solved by t-scene,
Is the led on the pump even on?
It appears you have the pump plugged into a fan header on the motherboard. Make sure you have the speed set a 100%.
popularlion ·
Posted in Troubleshooting1 -
CallMe_David ·
FancyPants101 ·
BoBo6107 ·
R_public ·
Posted in Networking14 -
apoyusiken ·
Posted in PC Gaming1 -
6
