PC overheat, need help!
Solved by t-scene,
Is the led on the pump even on?
It appears you have the pump plugged into a fan header on the motherboard. Make sure you have the speed set a 100%.
Doctah ·
Posted in Peripherals0 -
2
michaelb198 ·
Posted in Peripherals1 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards3 -
12
6
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
