So anyone who follows me knows I am currently overclocking the shit out of my 980 and I am looking to water cool it but it is artifacting like a strip on my screen at 1570MHz and I was wondering if putting a water cooler on it (reducing GPU temps) will reduce artifacts?
Thanks.
https://linustechtips.com/topic/403922-do-temps-effect-artifacts/
It's possible, maybe.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Thanks.
Possibly, you may also be artifact because you're overclocking to the extreme. What variant of the card are you using?
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
reference lol
reference lol
That may be part of it, it doesn't have the beefed up power delivery / cooling solution that custom cards have which would limit your ability to overclock and chances are you've hit your max overclock before you being to see much worse artifacting. To be safe I'd tone back your OC to the point where you don't see any artifacts and then once you have a better cooling solution you can continue to push your card further.
That may be part of it, it doesn't have the beefed up power delivery / cooling solution that custom cards have which would limit your ability to overclock and chances are you've hit your max before you being to see much worse artifacting. To be safe I'd tone back your OC to the point where you don't see any artifacts and then once you have a better cooling solution you can continue to push your card further.
Yeah I was going to dowclock at least until I get a water cooler but I don't want to get a water cooler for nothing.
I wanna see if I should water cool it or trade it for a custom card.
Yeah my old gtx 260 would artifact and stutter past 85*C, then I set a fan curve and left the overclocks exactly where they were, and it stopped.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
Honestly unless your system is already water cooled it's just gonna be a pain in the ass. I'd try and get something like the Gigabyte G1 Gaming Edition.
Oooo some first hand experience!
Lemme try taking off my side panel and ramping up all speeds.
NZXT Kraken G10, Corsair HG10 N980, EVGA 980 HYBRID Kit. Plenty of things that make it not a pain in the ass lol
I kept my temps under 60c and reached higher stables AND reduced artifacts so looks like i'm water cooling..
Thanks.
yes. my 980ti (reference) without artefacts = 1480mhz @ 63 degrees (100% fan speed), 1440mhz @ 84 degrees (about as loud as a 290x)
This is MOSTLY to do with GPUboost2.0 reducing core voltage as temps increase...
overvolted with GPUboost disabled and watercooled I get 1510mhz with no artefacts
so in short, yes, cooler temps = higher stable overclocks (on Nvidia cards)
but also, BIOS flash to remove GPUboost2.0 devolt will also achieve this (card will be hotter and louder)
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
