I have a monitor that has HDMI input but no audio jack. So I've got some speakers. How would I manage to get audio? Also I'm using HDMI to HDMI cable.
https://linustechtips.com/topic/403911-ps3-audio-helpm/
Those speakers only have 3.5mm input?
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5445919
Um, HDMI=audio and video in one not just video. O.o You might need a PS3 component cable though for what you wanna do.
I know. My monitor does not have an audio jack. 3.5mm
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5445932
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5445962
What @AlwaysSFX suggests.
Have it myself too.
You just plug in the component cables you got with your PS3 (PS2 cables work too), attach that thing and connect your speakers to the green thing.
Just be sure you have to go to settings > audio settings > audio output or something and change it to composite/component/SCART.
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5445988
Have it myself too.
Okay. Thanks! :)
@Minibois subwoofer only has one 3.5mm audio jack, how do I split it to my PC?
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5445999
You could also get one of those mini usb sound cards.  then you'd just need to select it as your audio source.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5446608
Can you recommend me one?
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5447066
unfortunately not, I've never used one, I went the more expensive option and bought a Astro Mixamp and plug stuff into that.
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5447125
Oh, okay.
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5447252
Get one of these, you can go on the PS3 and use HDMI for video and send the audio through your component or composite audio jacks, to this cable, to your speakers.
Where do I plug in the white and red cable?
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5451995
Where do you think..? Your PS3 comes with those cables. Red cable to red cable, white cable to white cable.
Oh. sorry, I don't think I have that cable any more.
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5452093
D: Why not?
My parents must've thrown it out.
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5452117
Buy the original cable that comes with the red and white audio cables
http://www.ebay.co.uk/itm/HD-Component-RGB-Cable-for-Sony-PlayStation-PS2-PS3-RCA-/131099785302?pt=LH_DefaultDomain_3&hash=item1e8627f856
then buy yourself one of these:
http://www.amazon.co.uk/kenable-Stereo-Socket-Sockets-Adapter/dp/B004HTHJNG/ref=sr_1_28?ie=UTF8&qid=1436545069&sr=8-28&keywords=rca+to+3.5mm
You can either plug your speakers directly into it or plug the cable using a AUX cable into the line in port on your PC, assuming you have one which you should.
https://linustechtips.com/topic/403911-ps3-audio-helpm/#findComment-5452149
