Hello LTT community.
I have Turtle Beach headphones and whenever I plug them in my desktop PC, I hear a lot of distortion and crackling noises even when I'm just idling on the desktop. I looked up ways to get rid of it, and a video I watched said DACs are great at removing Electrical Interference(the distortion/crackling noise).
So do DACs remove this electrical interference? If so, can you recommend good DACs that are not too expensive? Average cost I saw for a DAC was ~$70  :mellow:
PC: AMD Ryzen 5 1600 @ 3.8GHz | EVGA RTX 2060 SUPER | MSI B350 Gaming Pro Carbon | G.Skill Ripjaws V 16GB @ 3200MHz C14 | EVGA G3 650W
Laptop: 2023 Macbook Pro 16" - M2 Max | 64GB RAM | 1TB SSD
https://linustechtips.com/topic/403908-will-dacs-remove-electrical-interference/
yes.
you will need an amp too.
yes, assuming you're buying an external DAC.
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
are you plugging it into the front panel audio? or rear ports?
Absolutely not.
Moving to an external DAC can remove interference by getting the audio electronics away from sources of EMI inside your case. However, the DAC itself is not responsible for cleaning the signal in any way. Same goes for an external amp - moving away from the interference source is what matters.
I tried plugging it in both and I got the same interference with both.
yes.
Don't amps just give you the ability to change the volume with the device instead of changing the volume on the PC?
Also I forgot to mention, my headset is USB powered so I don't know if that has anything to do with it.
No
Well, that means that you're not using your onboard audio anyway. The interference could be coming over the USB connection or it could be the headset that is having problems.
Either way, an external DAC and amp won't help you unless you have an analog headphone or headset.
Kind of - a DAC alone is not designed to drive a headphone. You need an amplifier after a DAC to raise the voltage and provide enough current.
The really confusing part is this - most products called a "DAC" you'll be looking at actually also have an amplifier. If it has any sort of physical volume control, it has an amp. :)
