Hi,
My Mouse pointer is enlarged & appears to be magnified after install cat 15.7 driver in Windows 8.1. Anyone else have this problem & maybe a solution.
Tried already changing to normal size under mouse pointers under personalization.
The pointer looks like it in 600x800 res. when I have Res. set to 1920x1080 60hz.
Eric
cool bug bro....
try to uninstall the drivers manually through windowses "remove program" in the control panel. Then reinstal the drivers again.
You probably have a already corrupted section that got worse when installing the new drivers
