HELP ME IM NEWBIE
Go to solution Solved by ShadowCaptain,
Thank You ..
Dont bother getting the pentium, its not worth it over your current CPU
either play games at lower settings (i suggest keeping your resolution native, and keep textures medium/high and lowering other stuff like view distance and other things)
Save up and get a whole new system further down the line
Hello, i have this
CPU - A8-5600k APU
MB   - gigabyte FM-2 Socket
GPU - GeForce GTX 750 1gb
PSU -  450W
RAM - 8GB
(NOTE: ALL DRIVERS ARE UP-TO-DATE)
most of the game i played are lags even meeting the recommendation requirements eg: FIFA 15, wwe 2k15 , tomb rider, nba 2k15 etc . any tips ? THANK YOU!
https://linustechtips.com/topic/402252-help-me-im-newbie/
Hello, i have this
CPU - A8-5600k APU
PSU -  450W
RAM - 8GB
neither your CPU nor your GPU are very powerful
Are you trying to play in max settings?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5422969
Try turning the setting down? Not sure what settings you're trying to run them at, or at what resolution..but that might be the problem.
i dont really change graphic settings in -game, its automatically set by default . but i always put 0 on the FXAA / antiliasing
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5423005
overall it's not very powerful, I would recommend a PC Upgrade or a new PC all together
Because he had a hard drive.
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5423013
OP doesn't need to upgrade to run these games, a graphics settings adjustment is likely all that's needed for the time being. If adjusting the settings doesn't help then there is an issue because I have a system that's weaker than that and it runs more demanding games than fifa fine.
@OP just adjust the settings, the auto detect on some games is shit and theres no telling what kind of performance the auto setting will get you.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5423031
yep, it runs pretty well if I lower the settings which is not exiting.. hehe
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5423081
Thank You ..
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5423173
New GPU. The 5600k isn't a slouch. A G3258 won't improve your performance much or at all as it has some serious frame time issues once a game is making use of 4 threads.
For $200 you can get an R9 380 or GTX960.
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5423177
Yep, i just play with medium settings now and its quite good.. :)
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5432696
yeah the main issue is the GPU, the CPU while not the fastest is fine
If you want to play with better settings now get a new GPU, if you can wait, save up for a whole new system
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5432707
yeah i think i'm saving for future gaming pc.. thanks
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5432725
yeah but im afraid of bottleneck ..
Well you can get a faster GPU like the ones I mentioned and continue using your A8 just fine for the most part, getting a G3258 offers 0 improvement to you right now as you are GPU bound not CPU bound.
https://linustechtips.com/topic/402252-help-me-im-newbie/#findComment-5432759
