Hi, I am trying to connect my phone to a decoder that has a usb on it, it detects usb sticks, but does not detect my phone as a storage device. Is there any app or whatever that will allow my phone to be detected as a usb drive? Btw my phone is android and its rooted.
Thanks
https://linustechtips.com/topic/400854-android-phone-usb-problem/
Connect your phone to it, go to the notifications bar and press that notification about .. Something like USB connectivity. It bring you to some settings and you press media device or something.
That might work. Otherwise I wouldn't know.
Does your decoder support reading files off a portable device?
My TV doesn't do that.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
Don't think so
Then try using a USB thumbdrive if you haven't done so already.
