Asus Orion Pro headphones
Solved by Gorgatron,
Only one source can be set as the default in Windows. There is a program someone wrote called Default Audio Switcher or something like that to bind keys and switch between defaults. I'll try and find the link.
edit: not the one I was talking about but; http://www.raymond.cc/blog/easily-change-or-switch-the-default-audio-sound-output-in-windows-vista-and-xp/
Featured Topics
theTacticalShazly ·
4
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
5
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
