So I have a budget of $1200 (USD) and can stretch to $1500. My goal is to be able to play games like Borderlands at 60 fps and also multitask (watch videos or streams while playing). What kind of cpu would be most useful for this (hopefully Intel) and what motherboard would be best compatible for it? How much memory would I need? Is it better to have DDR3 or DDR4 for what I will use the computer for? What cooler should I use (air or water)? Also what case would you recommend?
(if this is in the wrong topic then please tell me which topic it should be in)
https://linustechtips.com/topic/399352-help-on-pc/
you need to take a youtube trip through linus videos.
and follow your topic.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
https://linustechtips.com/topic/399352-help-on-pc/#findComment-5382150
ME! ME ME ME!!!! Go with 8GB, DDR3, and an air cooler. Rest will be adressed below...
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler  ($19.98 @ OutletPC)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard  ($81.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory  ($89.99 @ Newegg)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($56.37 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($50.89 @ OutletPC)
Video Card: Zotac GeForce GTX 980 4GB AMP! Omega Edition Video Card  ($477.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case  ($69.99 @ Micro Center)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Total: $1190.08
Generated by PCPartPicker 2015-07-02 21:44 EDT-0400
https://linustechtips.com/topic/399352-help-on-pc/#findComment-5382170
