Project: I AM IRON MAN
diluzio91
This fricking bend took 4 pieces of tubing, my wife's assistance, slightly burnt fingers, and a pair of vicegrips to get in place... Totally worth it.
DAT BEND
<Insert joke here>
My first of 2 EL panels came in, So here's the album for fitting the top lighting.
Plexi Fixed in place
EL Panel wired and installed
Lit up. Hulkbuster Approves.
Got the mask almost complete.
Paint!!
and peel.
Still waiting on the EL panel for the front mask... The computer is sitting on my desk, windows is installed... Overclocking is complete... but where's the fun of showing off the final pictures before everything's complete!!
Paint!!
wow
looks sick man
why didn't I think of this method of lighting before  -_-
wow
looks sick man
There's a slight buzz, you have to mess with the positioning of the panel or the entire thing sounds like it's vibrating.
Where's the wire for that EL panel? I can't seem to find it in the pictures...
It runs through the top directly behind the motherboard tray. When the second EL panel gets here I'll show off the cable management in the back part of the case.
I meant "where (and how) does it connect to the panel"? In your pictures of the panel there is simply no wire visible
loving the build, but it seems like the sharp corner on the windows needs to be angled like all the other corners. It's just kinda sticks out.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
If you Didn´t paint the fins on the radiators it would have looked better but It´s still sexy af as it is
Floor is good to go. After a ton of polishing I got rid of all that orange peel
Removed the masking
And got it installed.
This is gonna be sexy. If you didn't have what seems to be an amazing wife (for helping you in this project), you could probably just carry this around with you and woo all of the women.
This is gonna be sexy. If you didn't have what seems to be an amazing wife (for helping you in this project), you could probably just carry this around with you and woo all of the men
Fixed that for you :P
wow
much fast
such machine
many red
Great final result but if i was to complain about one thing in the build it would be how the cable for the gpu goes over the tubing, this is a personal issue but otherwise awesome build
It came down to me not being comfortable with the bend in the cables routing them behind the tubes TBH
-snip-
Go on Instagram and look up @officialpcmr .
They posted some pictures of your build today.
Nice job! I've always been a "phan" (get it? Phanteks?) of the Enthoo Evolv. I really like the light up panels :)
You know that guy that games on a MacBook? I'm that guy.
Heh... yeah, I kind of outed my reddit username... Gotta go hide all the porn now.
Lovely, but I still don't like the black.
Area 51 2014. Intel 5820k@ 4.4ghz. MSI X99.16gb Quad channel ram. AMD Fury X.Asus RAIDR.OCZ ARC 480gb SSD. Velociraptor 600gb. 2tb WD.
Just for giggles, My wife took pictures of my ghetto photo studio set up in the living room.
The backdrop area
Using the projector as a studio light
I hung the back drop from a curtain rod and a door using some clothes line... yep.... but the results were good at least.
tthis is a very nice build the only thing I dont like is the hard tube that is going at an angle to the graphics card
Thanks Gobumon (SP?)
The bend was sadly more of a clearance issue than anything, If I made it 90* there wasn't enough straight tube to get a good seal on the fitting. I also do all my bends freehand.
I assumed that was the case but I was nit picking
Also. after some tinkering here's some benchmarks!
Stock clocks
CPU @ 4.3
Gpu at
1450 Gpu
4000 Mem
Temps were topping out at 68 (package) on CPU and 65 (core) Gpu.
