My friend wants to build a new PC to move away from his PS4,
he only has £300 so I need it to be within that budget.
I'm trying to convince him to get one so I need it to be as good as possible,
so it must be able to play newer games if possible.
I was thinking AMD for the CPU as Intel processors will probably take up half the budget
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/398919-build-for-%C2%A3300/
Cant see newest games in that budget, definetely not where i live :/ Im guessing you werent thinking 60fps maxed out right?
Definitely not, was thinking medium settings at around 40 fps
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376483
http://uk.pcpartpicker.com/p/YBjZ7P
-NO OS-
-NO dedicated GPU (Get a GPU latter in the PC's life)
Pretty good, might have to look into dedicated graphics though
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376512
Wait for skylake and an I3.. Big igpu improvements comming (Think it's september launch)
Also gives time to maybe stretch the budget.. I think £450 is about the minimum I'd build with.
That will give him a decent base he can at least expand from if he gets into it.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376540
Not enough money in the budget, get him to save up and get a GPU in 6 months time or something or alternatively get a GPU on ebay
That's what I meant, sorry didn't explain. meant as in he'd have to look into dedicated graphics later on
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376543
Is that the next gen of CPU's coming out?
I've heard bits and pieces but I know nothing about it
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376548
Get him to save more. Parts at that range have higher price to performance.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376556
CPU: AMD FX-6300 3.5GHz 6-Core Processor  (£79.19 @ Aria PC)
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard  (£39.59 @ Aria PC)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  (£48.01 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£40.00 @ Amazon UK)
Video Card: EVGA GeForce GTX 750 2GB FTW ACX Video Card  (£104.10 @ Scan.co.uk)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£28.48 @ Amazon UK)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£32.80 @ Amazon UK)
Total: £372.17
Generated by PCPartPicker 2015-07-02 14:27 BST+0100
No OS but has a dedicated GPU
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376576
-NO OS-
Bad build, why get a SSD when budget is already very low???
Echelon Mk 2.11
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376625
Total: £372.17
Bit over the budget but maybe better for him as it will perform a lot better so a little bit more
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376680
Its should perform equal to or better than a console.
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376688
SSDs, I now can't live without them.
You can't but others can #FirstWorldProblems
If he wants to build now, he can get this:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£138.31 @ Amazon UK)
Motherboard: MSI B85M-P33 V2 Micro ATX LGA1150 Motherboard  (£39.64 @ Amazon UK)
Case: Zalman ZM-T4 MicroATX Mini Tower Case  (£19.98 @ Novatech)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£36.98 @ Scan.co.uk)
Total: £311.45
Generated by PCPartPicker 2015-07-02 14:40 BST+0100
But he would have to use the integrated graphics until he gets a GPU which will be worse compared to being on a PS4. How about selling his PS4 to get a GPU?
Echelon Mk 2.11
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376701
Total: £311.45
There is is integrated graphics in the a10 too. That's what i am saying.
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376709
But then when he gets a GPU, the CPU will then be a bottleneck...
Echelon Mk 2.11
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5376730
So on the CPU side it will be incremental increase like last few releases from Intel, however With broadwell They significantly improved the igpu to where it's better than anything else available from either AMD or intel and Skylake is reported to have 50% more execution units than broadwell.
Should mean that any discrete card under 100GBP is defunct. (ex a 750 or similar / lower)
Obviously we cannot say for sure until it's released but it may well be worth the wait for someone that needs low to medium graphics requirements but may want to expand in the future.
That all said, if he needs it now, best bet is probably an AMD 860 with a card of choice.
http://www.kitguru.net/components/graphic-cards/anton-shilov/intel-to-boost-graphics-performance-of-skylake-gpus-by-50-per-cent/
Try this build.. note that you can probably save a bit here and there by finding better offers on various sites. And get Windows from reddit.. legit copy for about $15~
You very limited in where you can go with it but it should kick a consoles ass.
http://uk.pcpartpicker.com/p/XhKpkL
https://linustechtips.com/topic/398919-build-for-%C2%A3300/#findComment-5377027
