really need help please
Go to solution Solved by W-L,
wohoo thank you guys, only have $70 left for that bad boy
650W with overclocks is still good for that build but I would recoomend something else like an XFX PSU or Evga G2 since the Cooler Master PSU isn't that good in terms of build quality and mediocre for power quality.
http://www.hardocp.com/article/2014/08/19/cooler_master_gxii_650w_power_supply_review/1#.VZLybvlVhBc
can Cooler Master 650W GXII PRO provide enough juice for GTX 980 ti + i7 4770k + 8 GB RAM (may be 16GB for the future)
Definitely
Welcome to the forum by the way! Read the CoC here. Remember to follow your topics and I hope you enjoy your time here :)
https://linustechtips.com/topic/397535-really-need-help-please/#findComment-5359527
probably yes
Builds:
https://linustechtips.com/topic/397535-really-need-help-please/#findComment-5359549
Yeah you should be ok. Any OC you will be doing?
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/397535-really-need-help-please/#findComment-5359552
https://linustechtips.com/topic/397535-really-need-help-please/#findComment-5359810
