Hello,
Recently my mouse was flickering lights on and off when playing PC games or surfing the web. What i decided to do is open it and replace the wire i took out my microsoft mouse wire and replaced it with a Logitech wire i noticed that the colors in the Microsoft mouse did not match the  Logitech mouse so i decided to take the cables out and place it so it could match, So i did it and it was successful everything was working lights no flicking but it said USB not recognized i tried everything nothing works i replaced the wire with the old one still did not work anyone know the issue?  I would really appreciate it if anyone could help me solve this thank you.
https://linustechtips.com/topic/397517-logitech-mouse-help/
1. This goes in troubleshooting, not general discussion.
2. Proper grammar helps in actually understanding what the problem is. Run-on sentences suck for getting a (technical) point across.
3. Mouse model, and pictures of these wires that you have replaced would help us help you.
When in doubt, re-format.
https://linustechtips.com/topic/397517-logitech-mouse-help/#findComment-5359411
first, What Mouse ?
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/397517-logitech-mouse-help/#findComment-5359419
Was this moved?  It's in peripherals right now, and it's all right here, after all, this is about a mouse :P
Currently roaming the forums in boredom
I like mice and keyboards and the sort
Formerly TheFlurryGames
https://linustechtips.com/topic/397517-logitech-mouse-help/#findComment-5360914
