Help Me
Go to solution Solved by Altecice,
ily thanks bro <3
np, If you need help getting your USB to be bootable for instillation give me a shout.
Right i bought my pc about a year or 2 ago with win 8.1 pre installed on it, the comp came with no disk or anything and i forgot how i got the product key to activate windows, is there any way to get my product key from the pc itself? thanks in advance
https://linustechtips.com/topic/396841-help-me/
Did you change hard drive ?
there should be a small sticker with the windows activation key on the pc
Not anymore, Since Windows 8 onward you no longer get a COA sticker with a serial number on it. Keys from OEM's are now kept in the BIOS.
Getting the product key is quite simple so long as you have access to the Windows install. You can use software such as THIS to find your key to write it down.
To get your install media you only require the product key you lifted from your install and input it into M$ software here.
Quack 🦆
https://linustechtips.com/topic/396841-help-me/#findComment-5351344
Oh I didn't know that :D
Last time I dealt with oem pc's was a while ago
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/396841-help-me/#findComment-5351356
ily thanks bro <3
https://linustechtips.com/topic/396841-help-me/#findComment-5351374
From a Microsoft rep
The Product Key on a computer that has Windows 8.1 pre-installed is embedded in the BIOS on the motherboard. There is no longer any sticker with the product key.
When you upgrade to the final version of the free Windows 8.1, the activation will be automatic and use the embedded product key.
Hope this information helps.
Another Microsoft rep
With Windows 8.1, Microsoft has changed from stickers that have the product key that the user has to type in when installing the operating system to new BIOS embedded product keys. The idea is that by eliminating the sticker, you eliminate one of the easier ways for nefarious users to get a legitimate product key. Eliminating the product key sticker also removes any worry that the sticker might get damaged while at the same time eliminating the long and irritating process of typing in various letters and numbers when installing the operating system.
If the user has to reinstall the operating system on a machine that came with Windows 8.1, the installation process automatically grabs the software product key from the motherboard BIOS with no input from the user. This means that those familiar Windows product key stickers will no longer appear on the Windows 8.1 computers.
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/396841-help-me/#findComment-5351430
