New build need help ASAP
i havent OC, and the only thing i did on the BIOS was set it to default settings, i donnt plan OC this chip right now, should i go to the BIOS and turn off adaptive voltage?
thanks for all of your help
You can, but it won't really yield you any benefit. The danger of adaptive voltage is if you're stress testing and the motherboard spikes the voltage sent to the CPU to remain stable. It's something you should always turn off when overclocking because your voltages are already higher than normal to begin with, but it's not terribly important for standard use. It wouldn't hurt to turn it off though, but if you got a bad chip you might have to figure out where exactly you are and what you need to set to be stable. It'll open a small can of worms you'll have to address anyway the moment you start overclocking.
...wait you have a K series CPU with an h81 board? Nevermind Don't worry about it. You can't really overclock anyway as even if you don't overheat the CPU, you risk overheating the VRMs. Power delivery will be a problem even if your h81 board circumvents the built-in overclocking restrictions of the chipset.
