Mousepad Upgrade ($25 max)
Go to solution Solved by MattTheMayor,
i always see a lot of cs go players recommend the qck. also there is a mouse pad review and the qck is great mousepad for fps according to the mousepad buying guide from linus.
here's the vid
also i would go for the qck+
I'm looking to pick up a Zowie Fk1 soon and I would like to know which mousepad to get.
I currently use a Belkin mousepad with a gel-wrist rest
I am an avid player of CS:GO and Arma 3 so I would prefer something that would be suited for FPS games
Here are the things I've been looking to buy:
 ($12.99) Steelseries Qck+: http://www.amazon.com/SteelSeries-QcK-Gaming-Mouse-Black/dp/B000UVRU6G/ref=zg_tr_705323011_8
($8.99) Steelseries Qck: http://www.amazon.com/SteelSeries-QcK-Gaming-Mouse-Black/dp/B000UEZ36W/ref=pd_sim_147_4?ie=UTF8&refRID=01RCPPYC24RKYG5AEWW7
($24.99) Razer Goliathus Large: http://www.amazon.com/Razer-Goliathus-Large-CONTROL-Gaming/dp/B00ETHLU86/ref=zg_tr_705323011_10
($16.99) Glorious XL: http://www.amazon.com/Glorious-Gaming-Mouse-Mat-Pad/dp/B00NOD04CY/ref=zg_tr_705323011_1
https://linustechtips.com/topic/395615-mousepad-upgrade-25-max/
I would get the qck+
Steelseries stuff is very good and i know someone with a qck and it's just amazing.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/395615-mousepad-upgrade-25-max/#findComment-5337619
Can't go wrong with Qck+. Time tested.
https://linustechtips.com/topic/395615-mousepad-upgrade-25-max/#findComment-5337628
Do what I do. I just take a really hard book. And basically just use it as a mouse pad. :P
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/395615-mousepad-upgrade-25-max/#findComment-5337640
