"Multi-GPU: NVIDIA SLI & AMD CrossFire Support"
Yes sir it does.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/394608-motherboard-questions/#findComment-5324099
Yes; up to 2 way SLI and 3 way XFire.
The fastest way to tell is looking at the board and seeing if it has the respective logos on it.
https://linustechtips.com/topic/394608-motherboard-questions/#findComment-5324104
It would, yes. But I don't see much of a need to buy an aftermarket cooler for the G3258.
yes and no. it can be overclocked pretty well with the stock cooler, but my buddy pushed his to a staggaring (at least for a g3258) 4.8 Ghz when he replaced the stock cooler with a TX-4
https://linustechtips.com/topic/394608-motherboard-questions/#findComment-5324677
Switch that G3258 and put an i3. Thank me later
If you wont upgrade, put a b85m mobo and get a TX3 evo.
AMD 860K @ 4.3GHz ; Kingston HyperX Fury 2400MHz ; Asus A88XM-Plus ; Sapphire R9 270X 2GB ; 600W Tacens Radix VII AG 80+Silver  ; Cooler Master TX3 Evo
https://linustechtips.com/topic/394608-motherboard-questions/#findComment-5324681
That's sort of what I meant. You can push the G3258 some with the stock cooler, enough to waddle your way through to learn what you are doing. How to manage voltage, temps, and such.
After that I suggest looking at a cheap air cooler to replace the stock one. Suggesting air over AIO since they are generally a bit cheaper.
https://linustechtips.com/topic/394608-motherboard-questions/#findComment-5324731
Is there a unlocked i3 then ?
There doesn't seem to be, but you'd get better performance with an i3 than an overclocked Pentium.
Also, you won't need to spend $60 on a CPU Cooler since you get a stock one with the CPU. Spend that money on a better CPU.
If you want to get a Pentium, then I assume you're on a budget. If so, go for an H97 motherboard instead of a Z97 motherboard. You loose SLI and overclocking capabilities. But you won't be overclocking with an i3 anyways and if you're going budget, you could go for an AMD card since H97 motherboard supports Crossfire.
https://linustechtips.com/topic/394608-motherboard-questions/#findComment-5332239
