A few weeks ago, I swapped out my 4770k for a 4790k because I had gotten one super cheap. The differences were not worth it to me, so I moved back. Unfortunately, I cannot seem to quite capture the settings I had used properly once again. In order to maintain the same speed, I have to change my core voltage mode to static (from default adaptive) otherwise the CPU overvolts itself to 1.36v and melts down, whereas I am asking it for a stable 1.275. My question is this: I believe I had set the voltage mode in the bios to offset mode before I swapped out the chips, so that the voltage would still scale with performance but would not go beyond my target, however, when I try it this time around, I cannot even boot into windows. I reset the bios back to default to make sure no settings carried over in between, and yet the problem persists. Due to static mode, the cpu is staying at 1.275v all the time, and while idle temps are staying at 35c, I would like to reduce it if possible. Any help?
Edit: To be clear, 1.275 is the voltage that is stable at the 4.5ghz I had before. I just cannot achieve that voltage steadily without using static voltage mode.
https://linustechtips.com/topic/393602-4770k-voltage-question/
My question is why would you not use the 4790k? Temps are better, higher clock speed, newer cpu, and overall Devils Canyon, unrelated to the question. Lol
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/393602-4770k-voltage-question/#findComment-5311461
I needed the money for personal reasons.
Simply lowering the voltage to 1.138 to allow for the difference in adaptive voltage also cashes a blue screen, though I can at least boot into windows.
https://linustechtips.com/topic/393602-4770k-voltage-question/#findComment-5311549
To keep in mind, stock clock for 4770K is lower than for 4790K. So getting 4770K to 4.5GHz is much higher OC than what it would be with 4790K. Plus 35C idle is really good temp. Unless you have big WC rad, then its bit on the higher side.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/393602-4770k-voltage-question/#findComment-5312550
It is a custom loop cooled by a triple (thick) rad from EK. I had a stable 4.5ghz overclock from before at that voltage.
https://linustechtips.com/topic/393602-4770k-voltage-question/#findComment-5317973
