I need a 10 port unmanaged switch that is power via the wall. Amazon would be the best place. Please provide some links of some good ones.
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/391298-10-port-switch-stuff/
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/391298-10-port-switch-stuff/#findComment-5282071
Chase B
https://linustechtips.com/topic/391298-10-port-switch-stuff/#findComment-5282115
https://linustechtips.com/topic/391298-10-port-switch-stuff/#findComment-5282137
Cisco SG100/200 Series look on amazon.
I have an SG200-26p and its great but u can grab one with less ports, they have a 12 port model.
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/391298-10-port-switch-stuff/#findComment-5291198
