Any external USB power pack should work fine.  USB->lightning cable.  If you want to attach it to your phone a pair of thick rubberbands would do the trick.
Something like this would give you 4x the capacity: http://www.amazon.com/Anker-10000mAh-Portable-External-Technology/dp/B009USAJCC/ref=sr_1_3?s=wireless&ie=UTF8&qid=1434891713&sr=1-3&keywords=usb+power+pack
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/390903-external-battery/#findComment-5276631
I wouldn't buy "any external power bank" though. A lot are super crappy. I bought one that was $35 by Limefuel and it was the cheapest piece of crap that I have ever used. The battery reading was always off, the batteries were definitely not too reliable, and the USB ports were so cheaply made that only after a couple weeks of using it they broke. All of them. I had 2 of these power banks and I had the same issues on the 2nd one as well. It's clearly a manufacturing issue.
But anyways, I approve of Anker. I currently have their 20,800mAh power bank and it's so awesome. I've had it for a few months now, and it even survived a trip to Europe. Was there for 10 days and had to fully charge it once or twice I believe? Ya, Anker is great.
COMIC SANS
https://linustechtips.com/topic/390903-external-battery/#findComment-5279010
I personally have a 10,400mAh battery bank by Xiaomi (Yeah, the guys that made the Mi4 and the Mi Note).
2.1A, aluminum build, and it's around your budget the last time I checked (import costs not factored in)
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/390903-external-battery/#findComment-5301074
I have an Anker pack, and have since vowed to always buy anker products. I have a ton of their cables - they are great quality.
The anker pack has been through several transcontinental trips, and usually gets tossed around and beat up. Very nice fit/finish.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/390903-external-battery/#findComment-5301451
