Hey guys i  ran speed test on my pc and phone respectively and i noticed speed differences
Specifically ~11 mbps upload on my pc and ~29 mbps upload on my phone
My phone I am currently using is a Oneplus One
My pc specs are
i5 4690k
8gb ram
750watt gold ps seasonic
Mb - Gigabyte z97mx M-atx motherboard
EDIT: Is there any way to fix my upload speeds?
https://linustechtips.com/topic/390468-network-card-speed/
What is your question?
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/390468-network-card-speed/#findComment-5270915
Ah okay, well first things first.
- Dual band router?
- Dual band Laptop?
- Do you test laptop and phone from the same position (probably, but should asked).
There is always the possibility that the antenna in you laptop just sucks. I get pretty different speeds from my laptop/tablet/phone as well.
Is the download also different?
My System:
https://linustechtips.com/topic/390468-network-card-speed/#findComment-5270956
Hmm strange, might be a problem with the cable (though you'd expect problems with the down speed as well) or the drivers of your mobo. Have you tried updating the drivers?
My System:
https://linustechtips.com/topic/390468-network-card-speed/#findComment-5271000
