I'm building a new system with an i5-4690k. I'm building it for gaming and Youtubeing. I would like some help determining which cooler to get. I just want to know some good coolers (air or water) for less than $70 USD.
Thanks for any suggestions.
Youtube Channel: youtube.com/ExoGamer0529
https://linustechtips.com/topic/389363-cpu-cooler-help/
I hate to be that guy, but Hyper 212 EVO.  It's just too damn good.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/389363-cpu-cooler-help/#findComment-5256634
Probably the best you can get for exactly $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608041
or this, it's a better option than what I posted.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/389363-cpu-cooler-help/#findComment-5256638
It would really help if you mention what case you use. Some cooler might be too big/can't fit in certain case.
I'm using a Nanoxia Deep Silence 1. As far as I can tell, it is actually fairly similiar to the Define R_ Series from Fractal.
https://linustechtips.com/topic/389363-cpu-cooler-help/#findComment-5256666
The act of making videos and posting them to Youtube.
You mean uploading, being a YouTuber. I have never heard Youtubeing and I am sure it would be spelled Youtubing but I was just curious what you were saying by it, didn't mean to be rude in a way if I came across like that.
https://linustechtips.com/topic/389363-cpu-cooler-help/#findComment-5256702
Na, you're good.
https://linustechtips.com/topic/389363-cpu-cooler-help/#findComment-5256861
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/389363-cpu-cooler-help/#findComment-5257827
