no
an AiO pump is not enough for a custom loop
you either buy a good pump or stick to air cooling
https://linustechtips.com/topic/386759-cpu-block-with-pump/#findComment-5219631
I only need a 240mm radiator, no gpu
then buy a 240mm AiO...
https://linustechtips.com/topic/386759-cpu-block-with-pump/#findComment-5219662
I want a reservoir and custom piping(spellmaster) and I want to add a pump and GPU block later
If you're gonna do water cooling or liquid cooling. Just save up and do it right. You'll probably not be as happy with it if you ghetto rig it. If you're gonna spend that much money on your rig at least do it right.. Yeah, you can create something using an AIO. But what you're saying seems like more work than it is worth because you're going to get all the parts anyways. You want a CPU and GPU block. Also, pump.
Just grab a nice cheap air cooler for now. Save up for a custom loop. Then, create a build log on here. Let everyone see it and enjoy it too. It'll save you more headaches in the end.
ORRRRRRRR you could just get a swiftech H220X or something.
https://linustechtips.com/topic/386759-cpu-block-with-pump/#findComment-5219872
