CPU for gaming/streaming
Go to solution Solved by FratStar,
This works well for both gaming and streaming?
Yes It will work just fine. Also the Xeon is hyperthreaded while the 4690k is not. At the end of the day it's your decision, but I'm just giving you another option, but don't take my word for it do a bit of research and see if it's right for you. I'm an 8350 owner and personally I have zero problems but it was still pretty expensive I wish I went the Xeon route tbh would have been cheaper and better.
As for AMD:
I have the Asus Crosshair V and it's honestly the best if not one of the best boards and it's still expensive new and I've hit a much higher stable OC running this board than my previous one, but it's just not worth it.
Hey guys, I am building a PC for gaming and streaming on twitch.tv
I have decided everything as far as hardware goes, except for one variable. I need to decide between CPU's. My first option was the AMD FX-8350. My second was the Intel i5 4690k. The AMD benchmarks higher, and has a way better Multi-core speed. The intel has a way better single core speed. I would be gaming (usually a single-core task), and streaming (a multi-core task). I need to know which would be better for my situation. I am on a budget, so the AMD one would be better economically.
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/
How often do you plan on streaming?
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213525
"Why not both?"  If you can, get the Xeon E3 1231 V3.
Otherwise, go for the AMD and get that powerful GPU with it.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213532
774580b5532fdb81cb71e056d64efcbd5c8e16ec
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213543
Agreed.
Useful threads: Code of Conduct || Unofficial LTT Beginners Guide || Forum FAQ
CPU: Intel Core i5 4440 GPU: GTX 760 MOBO: Asrock Z97 Anniversary RAM: 8GB Adata @ 1600 Mhz Case: Define R4 SSD: Kingston V300 128 GB
HDD: 1TB Seagate Barracuda NAS: 3TB Seagate Barracudas in RAID 1 PSU: EVGA 600B (600W 80+ Bronze) Display: LG 23MP75 (1080p IPS @ 60hz)
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213558
you sure its not the 5th thousandth?
I believe he says fifth in the movie :P
edit: actually I think its third but w/e
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213567
Intel, provides more technologies and has better multi-threaded performance.
EDIT: Nevermind. Thought it did.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213600
Neither. Get a HT Xeon and an H81 board.
"Rawr XD"
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213628
To all the people that suggested a xeon:
To be more specific I'm on an 800-900 total budget, so that's kinda out of the question. It's basically between these two processors.
Um the i5 4690k cost about $240 while the Xeon I listed here costs ten bucks more. You can get an H87 motherboard for extremely cheap even a H97 board is pretty cheap.
Xeon: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117316&cm_re=zeon-_-19-117-316-_-Product
If you're not privy on that just get a 4690k what's the point of getting that without a z97 board (for all the bells and whistles) which would be more expensive than going the Xeon route, but to each his own.
EDIT: On amazon the 4690k is $235 the same Xeon is $246. I wouldn't want you buying into a pretty dead platform. Plus getting a good AM3+ motherboard will cost you especially if you want to push it close to 5GHZ, then you have to buy a beefier cooler etc. Then I again I don't know your exact build so what do I know.
Cpu: Ryzen 9 3900X – Motherboard: Gigabyte X570 Aorus Pro Wifi  – RAM: 4 x 16 GB G. Skill Trident Z @ 3200mhz- GPU: ASUS  Strix Geforce GTX 1080ti– Case: Phankteks Enthoo Pro M – Storage: 500GB Samsung 960 Evo, 1TB Intel 800p, Samsung 850 Evo 500GB & WD Blue 1 TB PSU: EVGA 1000P2– Display(s): ASUS PB238Q, AOC 4k, Korean 1440p 144hz Monitor - Cooling: NH-U12S, 2 gentle typhoons and 3 noiseblocker eloops – Keyboard: Corsair K95 Platinum RGB Mouse: G502 Rgb & G Pro Wireless– Sound: Logitech z623 & AKG K240
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213761
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213796
As for AMD:
https://linustechtips.com/topic/386250-cpu-for-gamingstreaming/#findComment-5213845
