Probably this isn't the right place for this thread
Hi guys, Vegas Pro 12.0 is giving me problems.
When i'm trying to open video that i recorded in Dxtory with codec "OpenEncodeVFW Encoder using AMD APP/VCE" i get this "Warning: An error occurred while opening one or more files, An Error occurred while opening Codec"
Now how to fix that?
Vegas Pro 12.0 that i'm using it's original but i'm sharing it with my buddy. (Could that be causing that issue?)
Sorry for my Bad english. :)
THANKSSSSS :)
https://linustechtips.com/topic/386032-vegas-pro-120/
-snip-
Record with a different codec or convert the files (the former one is highly advised)
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210891
Use a different codec or something. And for file format, I found that MP4 seems to work the best for me.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210901
recording with dirffrent codec is out of the options.How to Convert the files?
Not good with converting stuff..
You could import to Movie Maker, render with custom settings (with some high bitrate, 60fps, etc.) and try importing to Vegas again
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210948
Yeah, doesn't matter if it's AVI or not if the codec is some weird thing..
Try what I said above or else just record with a different codec
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210962
Do you maybe know some good codecs?
I have to end up with decent quality and Low MB, example 720p 30FPS 15 minutes 800MB :)
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210968
I don't know any other codecs, my Specs 8GB of RAM I3 4150 R9 280X.
Do not underestimate that I3!
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210983
What codecs are available in DXTory? And can you not just change some other settings, like bitrate, res and fps?
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5210989
yes i can change that but why should i?
I like these settings
never used it, maybe you can Google some good settings or whatever.
just something with decent bitrate (around 10 is fine if for YouTube) and 720p and 30fps.
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5211132
So i can't use settings that i like.... sucks....
EDIT: this shit is complicated
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5211306
Vegas don't support h264 format, you need to encode it to other format first before importing.
https://linustechtips.com/topic/386032-vegas-pro-120/#findComment-5211766
