Getting new internet from Comcast (Ugh) Need help picking network parts
Gilbert
So my dad ordered comcast services this morning and plans to get it soon.
I need help picking out a wireless access point and a modem for our house, it's a 3 story house with 5 people using the internet, two of them are heavy users of it.
The speed we're getting is 50/50
Budget?
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
Budget?
Nothing more than 500 dollars
A decent router like a Asus-AC66u/ ac-68u and a accespoint or range extender should do.
You can't go wrong with Ubiquiti, just depends on what standard you want to use, N or AC. You didn't specify if there are any ethernet users and if you have data installations in the house.
UniFi AP (N Only) - http://www.amazon.com/dp/B004XXMUCQ/
UniFi AP (N + AC) - http://www.amazon.com/dp/B00D80J2XU/- Highly Recommended
Cable Modem (300Mbps) - http://www.amazon.com/dp/B00AJHDZSI/- Highly Recommended
Router - http://www.amazon.com/dp/B007B60SCG/- Highly Recommended
Switch (If needed) - http://www.amazon.com/dp/B004ELA0SS/
N and AC?? Data installations?
No one in our house uses Ethernet so no need for that kind of thing.
Just get the Unifi AP AC, ARRIS cable modem and the router. Connect them up, configure them and you are done.
Side note, the ARRIS Modem is only a modem, it cannot route so you will need a router, the one I linked is pretty good. You could instead go with a router/modem device but they are a little more expensive, plus if you ever move to anything other than cable you won't be able to use it.
Ok, thanks man.
