I recently bought a WD passport 500gb. I plugged it into my computer and noticed it only had 465GB available.
My main rig is also advertised as a WD 1TB HDD, but I can only use 931GB.
Where are the other gigabytes? and is this false advertising?
About 100 explanations for that online :D its like that for every HDD and is to do with the 1000/1024 translation that most people don't know about
I saw a thread like this recently.
It isn't false advertising, I believe on the bottom or back of the package there is some explanation to this.
X99 WhoKnowsAnymore
CPU: Intel i7 5930K | Motherboard: MSI X99A Gaming Pro Carbon | GPU: EVGA GTX 1080 Ti Hybrid |
Manufacturers use gigabytes which are 1000 megabytes or 1 000 000 000 bytes.
Computers use gibibytes which are 1024 mebibytes or 1073741824 bytes.
Windows uses wrong names for the units that's about it.
It's because this stuff: https://en.wikipedia.org/wiki/Gigabyte
It explains it all!... But it's normal, everyone has that.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Hello there,
The confusion comes from the of the different measurement standards that are often used. We have a KB article explaining the situation here:http://products.wdc.com/support/kb.ashx?id=3CK31x. All HDD manufacturers report the capacity based on the definition for gigabyte  given by  International System of Units  and  International Electrotechnical Commission (IEC) . That would mean that all storage media size will be reported in GB where 1 GB =  1000000000 bytes.
