Nightshade Red Raijintek Metis (Finished)
Yeater
Hey I just wanted to introduce you to the build im gonna do for my friend.
He wanted a gaming pc that also can render some videos this is what i came up with.
I went with a red theme because he said that is his favorite color.
The name for this build is gonna be Nightshade after the bomb of RED 2
Share your thoughts below.
Hardware:
  • CPU: Intel Xeon 1231v3
  • GPU: EVGA GTX 980 a.c.x 2.0
  • PSU: Silverstone SX500-LG
  • MOBO: Gigabyte GA-H97N-WIFI
  • RAM: Kingston HyperX Fury Red 1866
  • HDD: 1 TB WD Red (need those colors)
  • SSD: 120 GB Samsung 850 Evo
  • Fans: Cooler Master Jetflo 120 Red Led PWM
  • Case: Raijintek Metis Window Red
  • Cooler: Kraken X31
Peripherals:
  • Mouse: Mionix Naos 7000
  • Keyboard: Cooler Master Quick Fire TK
  • Headset: Kingston HyperX Cloud 2 Pro Red
  • Monitor: LG 29UB55-B
CPU: 4790K (4.8 ghz) | COOLING: Custom Liquid Cooling (240 mm rad) | GPU: GTX 980 ti Superclocked+ (2x)  | MOBO: Gryphon Z97 Armor Edition | RAM: Kingston (4x4 gb 1600 mhz) | SSD: 850 Evo (250 gb) | HDD: Black (1.5 tb) | CASE: Enthoo Evolv | PSU: G2 850 (850 w) | DISPLAYS: Acer XB270HU bprz / Philips 246V5LHAB/27 (3x) | KEYBOARD: Vengeance K60 | MOUSE: Naos 7000 | HEADSEAT: H Wireless / Cloud 2 | For the exact parts visit my PCPartpicker it even includes my Desk and some other stuff.
980ti??  :( Also why z97 board with a xeon, you could save on the board and maybe squeeze in that 980ti. Wi-fi built in is not an advantage, unless you really need it built in.
how can i squeze in a 980 ti dont forget im  in switzerland  ;)  and the mobo is h97
My only concern is the 120GB SSD. Having lived on (currently) a 128GB SSD, you (end user) are going to want more, at least 240GB at a minimum unless you can use 2 drives one devoted to programs that need the speed (like Premier, Vegas, or Resolve).
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
dont worry its gonna be more then enough he doesnt need more space i asked him
Well 980 is even more overpriced in europe than it is in us.
i would get a 980 ti but he wants a fast processor for rendering so no 4460 or something like this
That is what he thinks now.... It will need an upgrade soon more than likely, unless he is installing everything to the hard drive, which would make the SSD next to useless.
Desktop <dead?>
i also use a 120 gb ssd and its enough for me and i use way more space then he does
Render with gpu  :lol:  :lol:
haha i dont think that a faster gpu will profit as much as a faster cpu
You say that, but I do not believe you.
120GB fills up nearly instantly if you are putting your programs on the SSD. If you are not putting teh program on teh SSD, you wasted your money on teh SSD.
Desktop <dead?>
Depending on teh editing program, it can eiuther add nothing, or the GPU will be much faster than a CPU ever could for much cheaper. That is assuming the program he is using has OpenCL or CUDA capability and that he is either realtime rendering, or renders often.
Desktop <dead?>
well then im sorry
he will use video editing software which uses cuda acceleration but it wont make a difference between a 980 or a 980 ti
well then im sorry
There is no need to be sorry. It is just how the drives work. If you are only running windows off the SSD, you are not going to get any benefit from the SSD investment. If you install your programs to the SSD, you are going to need about 240-500GB of SSD for most power users these days to have the OS and the programs. 120GB fills nearly instantly these days, especially with editing programs (adobe CC for example) where you have multiple 20+ GB programs sitting on the drive as well as the scratch disk space.
It will make a difference, just not enough to necesarily justify teh price increase (unless he is doing editing  professionally).
Desktop <dead?>
he just does it for fun
In that case, he will not see the performance difference between the cards. Depending on eth program he is using, you may be able to look at AMD cards also, a 290x should be a lot cheaper than a 980, and perform about the same (assuming he does not need cuda for anything).
Desktop <dead?>
thanks for moving the post i first realised that i am in the wrong section when i already posted it
That graphics card is way too long for that case. According to Raijintek website the max gpu length is 170mm.
Also it only has space for a single rear fan so it isn't ideal for a gaming pc imo.
http://www.raijintek.com/en/products_detail.php?ProductID=17
you can put in a longer gpu when you use a sfx powersupply
its possible to use a 270 mm gpu.
789046d1417438679-review-raijintek-metis
I came up with the name Nightshade thats the name of the bomb in RED 2
The MSI GTX 980 is 279 mm long though.
damn you are right no i feel dumb thanks so much
i thought it would fit because the stock 980 is 267 mm long
i guess he is gonna be getting a evga 980
