XSPC Photon Pump combo question
Go to solution Solved by W-L,
I am looking at water cooling and the kits save so much money.  I really want a separate pump and res though.  Has anyone separated the Photon 170/270 and pump and if so what parts did you get for the reservoir?
The Photon Pump/res combo units cannot be separated or adapted in anyway. you will need to get the straight reservoir and separate pump unit to do so if you want a separate pump and res.
They also sell the res on it's own and you can just buy separate pump.
