So I'm finally deciding to build a new system and I would be getting a Sapphire Radeon R9 270X.
By the time my computer is all built it's going to have:
16GB RAM
Intel® Core™ i5-4440
MSI H81M-E33
Antec VP-450 450 watts
Windows 8.1
2 SATA Drives
1 CD ROM
Will I have enough power to run the Sapphire Radeon R9 270X and then some?
https://linustechtips.com/topic/385067-video-card-power/
yup
https://linustechtips.com/topic/385067-video-card-power/#findComment-5198751
I'm running a 285 on a 500w so you should be fine, cutting it a little close on the 'and then some' though for anything worth while..
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/385067-video-card-power/#findComment-5198755
I would not recommend getting a 270x, It is just a 270 but overclocked from factory.
Id say you should step down to the 270(The performance is similar) Or stepping up to the R9 280.
R9 270 vs 270x vs 280(Give or take 10% since it is a synthetic benchmark.
http://www.videocardbenchmark.net/compare.php?cmp[]=2766&cmp[]=2702&cmp[]=325
You should be fine with that PSU.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/385067-video-card-power/#findComment-5198769
Id say you should step down to the 270(The performance is about the same anyways) Or stepping up to the R9 280.
I think I will get the normal 270. It only takes around 150 (correct me if I'm wrong).
https://linustechtips.com/topic/385067-video-card-power/#findComment-5198782
I'm not sure I like running that close. If the power supply can supply 450W but 80 percent efficiency, it would be about 360 watts.
That is not how it works. The power supply still supplies 450W, but with an 80% efficiency that means it has to draw 560 watts from the wall to reach that wattage.
https://linustechtips.com/topic/385067-video-card-power/#findComment-5198784
