does it matter if i go with an old odd?
carguy86
i had to cut my budget a bit so im wondering if using an old sata ODD would make a difference? (going to use it to install drivers, windows and games,)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
No... Why would it? As long as it has the modern connectors it'll work.
  1. Please don't install Windows by CD, use USB
Please don't install drivers by CD, use USB, or the manufacturer's website.
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
Nope. But i would recommend downloading the drivers from the likes of Intel and from your mobo manufacturer website; those driver install discs never install them correctly and use outdated drivers. Or at least from what i've experienced.
so you are saying that it dosent matter. (and cant i install driver cd and update the drivers later?
My pc:
(Black Glacier)
My server:
  • Please don't install Windows by CD, use USB
  • Please don't install drivers by CD, use USB, or the manufacturer's website.
Why not install via CD?
Longboarders/ skaters message me!
