I just started learning differential equations. I had the basics down last semester. But for my own project I need to solve a non-linear differential equation.
http://www.wolframalpha.com/input/?i=-y%28x%29%27%3Dcy%28x%29%5E2%2Bk
^From wolfram alpha. What I don't get is what is a1?
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/383540-math-help/
it has a number :0
No as in I don't understand the meaning of a1. Where did it come from? Like in integration, the indefinite integral of x is 0.5x^2 + C, where C is the constant of integration. So in differential eq, what does the a1 mean?
https://linustechtips.com/topic/383540-math-help/#findComment-5178327
Alpha is just a placeholder variable for any real number. Look at what happens when I replace "k" with 2.http://www.wolframalpha.com/input/?i=-y%28x%29%27%3Dcy%28x%29%5E2%2B2
This time you still have a constant of integration "k1" in your answer, rather than it being called "alpha1".
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/383540-math-help/#findComment-5178348
OHH I get it thanks! So alpha 1 is just there to tell you that any real number plugged into alpha 1 will make the differential equation true?
https://linustechtips.com/topic/383540-math-help/#findComment-5178448
Do yourself a favor and don't learn from Wolfram Alpha.
I'm not learning from it. I'm using it to solve a drag differential equation with the force of friction.
         F= Drag + Friction
     ma = kmvukmg
  dv/dt = cv2 + k
I just need to solve for v.
https://linustechtips.com/topic/383540-math-help/#findComment-5178590
