HELP! 4790k overheating ?!
Go to solution Solved by Lays,
so 35-38c idle and 70c max at load is good or i could get more by try lowering the vcore a bit and see if it will be stable ?
and any advice about fan controlling software or should i get fan controller and any case 120mm fans suggestions
Yeah you can try and lower the v core to see how low you can run it without it crashing.
I like fan controllers a lot more than software just because it's easier to adjust speeds, only downfall is you can't have a fan curve.
It's mostly personal preference though. For fans, check out the cougar cf-v12hp, I think they make a black version instead of the orange. They perform amazing.
Pc Specs:
Mb:Gigabyte z87x-oc
Ram:8 gigs of corsair vengeance 2133Mhz
Cpu:4790k
Cooler:Noctua NH-D15 Dual Fan
PSU:Seasonic 750w M12II Bronze full Modular
case:CM 690 III
Gpu:Gtx 650 oc and i know i will upgrade not now
Sooooooo......
ATM iam running 4790 at 1.150v Vcore This is as low as i can go either way it crash after it boots into windows and Vrin at auto but sometimes and i mean sometimes i can run it on 1.650v never tried to make it stable and everything else on auto turbo boost and it max watt tried turning it off and do it manualy got to 4.2ghz stable at max at this volt
Lastly i Idle at 32c-35c and when i run  occt i get at load i get 58c-67c but i doesn't load my cpu to the full 60%to77% max and it runs at 4.3ghz turbo boosted  then i ran AID64 i loaded my cpu to the max at 100%
load but still at 4.3Ghz i think this is cuz the turbo multi is set to auto which means 44  44   43  42 or somthing and the temps were 59c-67c never got past 70c only once now for the big boy Mr PRIME95
Small FFts  i get and omg from 80C-85C!!!!!!
Blend Test i get 59c-65c
In Large FFts is about the same with couple degrees above
and i verfied the voltage from cpuz ofcs hmmm idk i think i should get better temps
lastly i live in egypt and it hot here man oh man but my pc sets in my room so no worries my room temp is about 24c-26c max cuz air conditioning running non stop so yeah anyways i have an exam wish me goodluck and sorry for my bad english :D
https://linustechtips.com/topic/382613-help-4790k-overheating/
oh and one last question ways to make a chart for fan control i want my case fans and cooler to stop spining can do it in bios on pwm ratio and gigabyte software sucks tried speed fan can't seem to get it to work and i have 1 stick of 8 gig ram crucial tactial somthin comin my way if i stick the same one later will it work in dual channal ?? with the 2 corsair sticks in dual channal already
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166121
Running at 1.64v im surprised its not dead.
You never want to run Prime95 on Haswell chips stick to AIDA64 *EDIT* Intel burn test is also an option.
Try going into your BIOS and seeing how high of an OC you can get at 1.150v, 1.6 Is dangerously high.
Nvidia is to Dr Dre Beets as AMD is to KFC.
One makes you broke, the other you can get more of and have a midnight snack from the fridge when hungry again. Once you go Nvidia, you go broked, turn into an Elitist, or get the incorrect amount of VRAM.
- WCCFTECH
 I was only 9 years old. I loved Fifflaren so much, I had all the NiP merchandise and matches pirated. I prayed to Fifflaren every night before bed. Thanking him for the life I have been given. Fifflaren is love I say. Fifflaren is life. My dad hears and calls me a fuckhead. I knew he was just jelly of my passion for Fifflaren. I called him a Sw@yer. He hits me and sends me to go to sleep. I'm crying now, and my face hurts. I lay in bed and it's really cold. A warmth is moving towards me. I feel someone touching me. I feel someone touching me. It's Fifflaren. I am so happy. He whispers in my ear; "this is my pyjama". He grabs me with his powerful Swedish hands and puts me on my hands and knees. I'm ready. I spread my ass cheeks for Fifflaren. He penetrates my butt-hole. It hurts so much but I do it for Fifflaren. I can feel my butt tearing as my eyes start to water. I push against his force. I want to please Fifflaren. He roars a viking roar as he fills my butt with his love. My dad walks in. Fifflaren looks straight into his eyes and says; "He is a ninja now". Fifflaren is love, Fifflaren is life
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166129
I've gotten up to 1.53v trying to get a bootable 5.3GHz... Gave up after that point. I can boot 5.2 @ 1.36v, but I can't run benchmarks till I get to 1.42v or sometimes 1.43v
http://valid.canardpc.com/7kitru
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166143
1.6 isn't vcore it's vrin i know i needs to be +0.5 than vcore right ?
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166157
That's VCCIN.
That's the voltage the CPU gets before the FIVR inside the chip divides it up between the cache, memory controller, v core etc.
Intel burn test isn't really any better for testing, IMO Aida64 is one of the best right now, or Intel's XTU (extreme tuning utility)
XTU is the best IMO, because you can also change settings with it as well.
@Hoda Ali you should be running closer to 1.8v VCCIN, stock VCCIN is around 1.778-1.8v, lowering VCCIN is probably why you're having stability issues.
Are you trying to overclock the chip, or run the lowest voltages possible without giving up stability & still having a good overclock?
With an NH-D15 you should easily be able to run 1.25vcore, 1.9 VCCIN with 4.4 to 4.6 ghz on the CPU.
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166212
That's VCCIN.
I run XTU about the same 58c-65c Never hit 70c
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166224
XTU is a much better stress testing program than prime95 for haswell, prime95 seems to run much hotter than other tests on this platform.
also check my post from before, I editted it.
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166229
That's VCCIN.
i know the stock is 1.8v indeed and stock vcore for my chip at least was 1.350v which is so much i don't want to overclock if i want it will be way different i saw that i had temp issues so i though lets see my chip real stock vcore which is 1.150v atm iam leaving VCCIN at auto in bios cuz playing with sometimes make the system unstable i can run the cpu at lower vcore it can idle but when i stress it ofcs it crashes lowest is 1.000v mid way was 1.105v but stable is 1.150v so any suggestions?
i don't mind overclocking a bit i may run at 4.5ghz turning off turbo later if the temp issue is solved
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166264
Your temp issue already seemed to be fine if you're only hitting 58-65c in XTU.
My recommendation, try 1.215 VCore, 1.85 VCCIN, 45x multiplier, see if it's stable with XTU's stress test.
Your temps should be in the mid to high 60's, maybe low 70's but that's alright.
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166274
 @Lays i will try this but one last thing i can disable turbo boost in bios and apply all the setting but will it change when i open xtu. cuz i can't seem to find turbo boost disable option in xtu
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166299
You could, you don't really need to turn it off though, changing your multiplier kind of overrides it.
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166304
sooo i run it at 1.215Vcore and 1.850 VCCIN and 45 multiplier and here the result of just 1 min stress test 70c avarage somtimes spikes to 75c for a sec but stable most of the time at 69c-70c to setting i don't know what to do with them the vcore adaptive and static and cache voltage offset some people say but it at 0   oh and there some i think called voltage somthing protection it mean that it will make the vcore more stable and not jump around @Lays
https://imgur.com/CZXNLfG
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166378
Those temps are a tad high for the voltage and clock speed, but not insanely high or anything.  I wonder if you don't have air bubbles in your thermal compound, or if your cooler isn't making enough contact pressure with the cpu.
idk maybe a link for linus paste applicaton method would be great i know i saw one at ncix last year but i know i apply it right i don't know. an image would be great :D ty
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166385
I highly recommend you use static. Adaptive is not good for stress testing, because sometimes it will pull more voltage then you tell it to, and can overheat things.
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166404
and the cache voltage offset set to 0 or leave at 299.8046875mv ? @Lays
It's OK you can leave that alone.
That's for your cpu's cache.
You can overclock that too, but it doesn't help as much as your core frequency.
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166458
and any advice about fan controlling software or should i get fan controller and any case 120mm fans suggestions @Lays
and ty i know i ask alot sorry i bother you :)
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166480
https://linustechtips.com/topic/382613-help-4790k-overheating/#findComment-5166487
