My first build/gaming rig + questions
Solved by lukky211111,
Thank you for your advice, for the radiator replacements, should I get the p14 models instead of the a14's, and for the others just the a12(a14 for the rear)( http://puu.sh/ifiyk/286bc15f51.png) ( http://puu.sh/ifiAm/37987ebb95.png ) The model name's rather confuse me x.x
also id like to correct myself the p series were for the 120 mm only and those look to be more for cpu coolers and such the series i was thinking of are the industrial that run at around 3000 rpms sorry if this caused any confusion. the nf f12 is what you are looking for for your radiators though
