Question about pc build
Solved by Xaring,
Get an 17 4970K or an i5 4690K, and fit a 970/980/980Ti instead. If you are going to use the PC for gaming, you don't generally want to spend more on a CPu than on a GPU
ken43 ·
Posted in Troubleshooting3 -
5
thedood2k ·
Posted in Power Supplies3 -
1
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
