Every time i play a game for about an hour i get a blue screen. need help to figure out whats causing it so i can fix it!
post-3583-0-21480100-1374449209_thumb.jp
CPU: Intel Core i7-4790k @4.8GHZ COOLER: Corsair H100 | MOBO: Gigabyte Z97 Gaming GT| GPU: EVGA Geforce GTX 660ti SC 2way SLI | RAM: Gskill Ripjaws 4x2GB (8GB) | Soundcard: Asus Xonar Essence STX
| SSD: Intel 520 (120GB)HDD: WD Red 3TB | PSU: Corsair TX850M | Case: Corsair 750D  | Display #1: Samsung S24b350HL | Display #2: Acer Al1916W
 Keyboard: Ducky Shine 3 | Mouse: Roccat Kone XTD | Headset: AudioTechnica AD700X
https://linustechtips.com/topic/38135-blue-screen-problem/
Specs? And any game or a specific game?
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490280
Account for game settings. This could play out too
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490288
Basically every game. i have an i5 3570k, gtx 660ti in dual sli, 8gb corsair xms3 ram,tx850m power supply, asrock extreme 4 gen 3 motherboard.
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490303
Any fans blowing like a turbine before that?
nope everything sounds normal
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490304
Try disabling SLI.
Wait. Do you have Intel's graphics drivers installed?
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490306
Asrock board? *shivers* Have you installed any programs recently?
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490307
Try disabling SLI.
yes i do have intel graphics driver installed
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490311
only new games.
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490313
only new games.
Strange. What Do you have for a HDD and what program do you have for the games?
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490316
Try removing those. I got the exact same BSOD before, and I removed those drivers and the BSOD never came up again.
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490317
seagate barracuda 1tb drive
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490322
okay, will do hopefully it will work!
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490325
Yeah, that stop code is and apc index error and is typically associated with driver mismatch or overheating. And like godly gamer said, you're using the wrong driver most likely
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490335
Have you tried downloading BlueScreenView?
That'll read the memory dump and should in theory point you in the right direction.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490406
Thumbs up to BlueScreenVIew. I use it a lot when I try to help people with BSOD´s. Its just so much easier as it points you to the specific .dll/driver thats causing the problem, and making it so much easier to narrow down the problem.
Here is a link. Download links are at the bottom of the page: http://www.nirsoft.net/utils/blue_screen_view.html
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490508
i uninstalled them but now when i alt tab out of a game or change the resolution the game flickers with a green color.
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490516
No. Not wrong driver. Just the driver causing issues.
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490520
by them i mean the intel graphics driver
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490522
Well what is the current driver for your GPUs?
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490524
326.19
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490530
should i reinstall the intel graphics driver
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-490559
  • 3 weeks later...
so i thought i fixed the problem but it just keeps coming back i need help
https://linustechtips.com/topic/38135-blue-screen-problem/#findComment-568498
