Hello, first of all, I'm sorry if this is considered the wrong forum to ask, but I would rather not ask in just air cooling or water cooling because of the nature of my question.
Basically, I want to know what the quiet, most efficient cooling for a cpu is for under $100 CAD; be it air cooled, or water cooled (preferably closed loop).
If I go with water cooling, my case will only allow for a 120mm radiator.
Thank you for answering if you do.
Edit: Max height my case can take is 155mm (6.1 inches)
 A picture of my PC to give an idea of the limitation's I'm dealing with. (disregard the wiring. I took a picture just after everything was in. I have since cleaned the wiring up.)
https://linustechtips.com/topic/381172-cpu-cooling-question/
Corsair H60?
Build: CPU: i7-4790k @4.4 GHz 1.2v | GPU: Sapphire R9 380 Nitro | Memory: 16GB Evga SSC | Storage: 250GB 850 Evo, 1 TB Toshiba HDD | Mobo: Gigabyte GA-Z97X-Gaming 7  | Cooling: Aigo T120 RGB | Case: NZXT S340 | PSU: Antec HCG 520w | OS: Windows 10 | Keyboard: Corsair K70, Cherry MX Reds | Mouse: Logitech G600 | Monitor: LG 27UD58-B | Headset: Audio-Technica M40x w/ Modmic and Bravo Audio V2 Tube Amplifier
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149050
NH-D15 or dark rock pro 3 if you want black
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149051
Corsair H60?
air coolers like the NH-D15 perform a lot better while still being quieter
uless you want AiO for looks, anything under a 240mm radiator is not really worth it compared to air coolers
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149055
Corsair H60?
EDIT: Did not see the quiet part, I only saw the efficient. Disregard unless you are planning on getting quiet fan(s) and this was supposed to go on my earlier post lol :)
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149056
My CPU temp never goes above 52 degrees when folding 24/7 overclocked to 4.37 GHz with a H60
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149066
well thats because you have an AMD CPU and 52C is normal
a NH-D15 is still a lot better than a H60
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149113
ok
https://linustechtips.com/topic/381172-cpu-cooling-question/#findComment-5149213
