I have the NZXT S340 and want to be able to control my case fans. I cannot have a standard fan controller as they require a 5.25" bay I do not have. I was tempted by the Grid+ but it didn't seem worth it for the price. Just something to lower the speeds of a couple of 3 pin case fans. I'm from the UK so preferably shipping from there. Thanks!
Project: Veronica
  • CPU                  Intel Core i5 4690K @ 4GHz
  • Motherboard   ASUS Z97 Pro Gamer
  • RAM                 Crucial Ballistix Elite 16GB (4x4GB) 1866MHz
  • GPU                 NVIDIA GeForce GTX 1070 Founders Edition
  • Case                NZXT S340 Red/Black Edition
  • Boot                Samsung 850 Evo 256GB
  • Storage           2 x 1TB Western Digital Blue Hard Drives
  • PSU                 Corsair CX600M 80 PLUS Bronze
https://linustechtips.com/topic/379696-cheap-fan-hub/
GRID+ is the best PWM hub that I know of and matches your case aswell!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130847
True. It's designed to fit in it. It's definitely an option. Just hoping for something cheaper than £30.
Project: Veronica
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130856
I have the NZXT S340 and want to be able to control my case fans. I cannot have a standard fan controller as they require a 5.25" bay I don't not have. I was tempted by the Grid+ but it didn't seem worth it for the price. Just something to lower the speeds of a couple of 3 pin case fans. I'm from the UK so preferably shipping from there. Thanks!
The GRID+ isn't PWM capable just to mention, and as for controlling the fans you can use splitters off your motherboard headers and control it via the motherboard software. It's a good rule of thumb to have no more than 3-4 fans per header to ensure it doens't go over it's 1Amp capacity.
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130880
I don't think I can control the voltage of fan headers on my motherboard (ASRock FM2A75M-DGS). I can control PWM though but that's a given
Project: Veronica
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130897
You should be able to control the fan headers on the motheboard via voltage control in the BIOS at the least if there isn't a software on their site.
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130920
£30 isnt that bad for a nice fan hub, I would pay that!
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130934
I just don't need anything fancy so I was hoping for less.
Project: Veronica
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5130971
ASRock don't have any software from what I'm aware of and when I've tried in the past, I could never get 3 pin fans to change speed on the motherboard. I will try again though.
Project: Veronica
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5131100
I couldn't control any of the fans from the motherboard. The only won which will change is the CPU as it's PWM.
Project: Veronica
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5140090
Hmm that's inconvenient, if should atleast allow you to select DC voltage control over PWM though to allow you to control your 3 pin fans
https://linustechtips.com/topic/379696-cheap-fan-hub/#findComment-5140188
