So my mom recently got a laptop from her friend for a decent deal ($55) just for around the house use, it's a Dell Inspiron 15R, with i5-2430M, 4GB of RAM and Windows 7 Home Premium, seems to be original as it has all the bloatware on it.
So far it seems to be excellent hardware wise except for one thing which is the fan. It's always on which isn't a big deal, but it's loud and is constantly revving. It won't stay at a constant speed, and feels like it's getting power applied to it for a second, then off so it slows down for a second, and then repeat. It's not consistent either, the gaps between revs fluctuate, it's not a constant gap. Like this, but with fan noise rather then exhaust. https://youtu.be/r8hG3bDI7Dw?t=8s
Anyone know what's going on or how to stop it from doing this? The noise of it gets really irritating.
-It does it in the BIOS as well, not just in Windows
-Took it apart and cleaned the fan and heatsink, unplugged fan and plugged it back in again, still the same
-SpeedFan doesn't work, even with Dell control enabled
"Rawr XD"
https://linustechtips.com/topic/379216-laptop-fan-revving/
its likely the cpu is overheating. Check the temps with a monitor like hwmonitor
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/379216-laptop-fan-revving/#findComment-5124313
If temps look fine, it could be an issue with some on-board circuitry or maybe the fan itself.
https://linustechtips.com/topic/379216-laptop-fan-revving/#findComment-5124324
It's at around 45c browsing the internet, so definitely not a temperature issue.
"Rawr XD"
https://linustechtips.com/topic/379216-laptop-fan-revving/#findComment-5124337
hmm, thats annoying. May just be a very poorly implemented fan curve. Not sure if there is anything that can be done about that if the controller is separate from the rest of the system
https://linustechtips.com/topic/379216-laptop-fan-revving/#findComment-5124368
Oh no I had exactly the same problem on exactly the same laptop except that mine shuts off after one "rev cycle" and I still haven't fixed it. I even replaced the CPU thinking the temp sensor was bad and nothing changed. In my case I think that something in the motherboard circuitry is bad.
https://linustechtips.com/topic/379216-laptop-fan-revving/#findComment-5124514
