First Gaming Pc Build NEED HELP!
Go to solution Solved by General_Led,
Ok thanks
If i went with my original build how much power would be enough
500w would sufice however I would go with perhaps a 650w if you want to upgrade and do some OCing in the future. Also absolutely no need to waste money on ram cooling.
I am trying to decide on what to get while keeping it cheap but am not quite sure if it will all work together.
Case:DeepCool Kendomen ATX Mid Tower Chassis Titanium
MotherBoard: ASRock 970-PRO3 R2.0
CPU: AMD FX-8320 8 Core Black Edition
CPUCooling: DeepCool Gamer Storm Maelstorm 120K
GPU: MSI Radeon R9 270
RAM: Corsair Vengeance CMZ8GX3M2A1600C9B 8GB 2X4GB
RAMCooling: Corsair Vengeance Airflow Fan
PowerSupply: ???
I also have a 500GB WS Caviar Green That i could use. Are hybrids a good option?
Any Help is appreciated.
https://linustechtips.com/topic/379155-first-gaming-pc-build-need-help/
I need to know your total budget
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Assuming USD:
http://pcpartpicker.com/p/T7pYYJ
add a fan if you need to.
Solitaire.
Pretty much agree with it except I would get a 7200rpm HDD and I personally don't see a reason for a cd drive.
Windows install, drivers, i know you dont use it after that, but it makes EVERYTHING easier.
Solitaire.
Ok thanks
