Mobo layout
Check the BIOS there should be on option to vary or change the speed of the fan there, some motherboards will match the CPU fan speed or keep it at idle/max speed and not let you change it however.
https://linustechtips.com/topic/378955-fan-not-spinning/#findComment-5121133
This probably. It probably has a too low startup voltage, but if you give it a little push it'll continue on it's own. Getting something to move is difficult, keeping it moving is much easier.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/378955-fan-not-spinning/#findComment-5121151
