550w power supply enough for i7-4790k, 980ti and 2x3.5 hard drives?
bydus
Like in the title will 550w power supply handle such config without skipping a beat?
Should be yeah.
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
Depends on what psu it is.
A good quality one from let's say Seasonic, XFX, EVGA should work fine.
Easily.
If your chip isn't over clocked, I would say it'd be OK
Personally, I would want a little more headroom, but my entry level Corsair which is a CX430 handles my i3 4160, SSD and HDD and R7870 GPU without any signs of struggling.
What is the make and model of your PSU?
Depends on the efficiency.
650w gold 80+ psu would be enough.
Yes
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
Terve!
You'll need to tell us what 550W PSU.
Cannot tell you more right now.
Also: If you have a crappy PSU, I would not take the risk of your PSU killing you nice new GPU.
Sayonara!
I'd go with 620
Efficiency has nothing to do with the wattage.  A 550 crap power supply will still supply 550 watts, but may draw 650 watts from the wall, where a good one will also supply 550 watts, but will only draw 600 watts from the wall.
no it doesn't.
I'd go with 620
He better go with a quality 500 Watt PSU, then with a crappy 620(?)Watt one ...
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
OC3D has a nice graph that shows the power consumption of their system with an overclocked 4960x (Uses ~50% more power than a 4790k), 4 sticks of ram (Uses ~100% more power than 2 sticks of ram), and an overclocked gtx 980ti drawing only about 457 watts.  Taking the power supplies efficiency into account this means the whole system only required about 410 watts to run.  I'm pretty sure 550 watts is more than enough.
no it doesn't.
I made no mention of a "crappy" 620W...
no it doesn't.
Ok, let him install 600w psu with 10% eff and ruin the system.
This was already explained by Speaker..
i7 8086k @ 5.3Ghz / 32GB DDR4 Trident Z RGB @ 3733Mhz / Aorus GTX 1080 11Gbps / PG348Q
you obviously have no idea about PSUs and therefore better avoid those threads in the future.
still a higher quality 500/550W psu is a better choice, than a lesser quality 620W one ;)
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=324
Not sure if all crappy PSUs live up to their ratings
And vice versa for the 620w...not sure what you're alluding to.
How will He have 10% efficiency ?
