Is 600 watts enough for my system?
Go to solution Solved by WereCat,
Yes, more than enough actualy.
Hey =)
I'm upgrading my computer and I'd like to know if 600 Watts are enough to power it. Could I overclock the graphics card with this 600watt PSU?
My PC specs:
Processor:                     Intel Core i7 4790K
Graphics Card:              Gigabyte GTX 970 G1 Gaming
Motherboard:                 MSI H97 Gaming 3
Power Supply:                Corsair CX600 (enough?)
RAM:                             G.Skill Ripjaws 16gb (4x4gb)
Case:                             NZXT S340 (White)
CPU cooler:                   BeQuiet Shadow Rock Slim
Thank you! =)
Yes.
Thank you! =)
I'm running a similar setup off a low-quality thermaltake PSU, you'll be fine.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
Yes
CPU: AMD FX-6300 4GHz @ 1.3 volts | CPU Cooler: Cooler Master Hyper 212 EVO | RAM: 8GB DDR3
Motherboard: Gigabyte 970A-DS3P | GPU: EVGA GTX 960 SSC | SSD: 250GB Samsung 850 EVO
HDD: 1TB WD Caviar Green | Case: Fractal Design Core 2500 | OS: Windows 10 Home
Do you already have the CX600?
If so, yes it's fine, however if you don't have it already there are often better options for the money if you are buying at full price
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
