Hi, I have a Corsair Vengeance case.   I have two 120mm fans toward the bottom in front pushing in air.   The 120mm at the upper back fan is blowing air out.   I also have two 140mm fans on top of the cases blowing air out.   I have a question about the two 140mm side fans.   They align up to my 2x GTX 980s in SLI.   Should I have them blowing air towards the GPUs or pulling air out?  Most of the fans are Noctua.   I have a 1250W Seasonic PSU at the bottom that brings up and out the back so it shouldn't affect the temperature in the case (I think :-) ).
Thank you.
David
Here's a link to my case:
http://www.corsair.com/en-us/vengeance-c70-mid-tower-gaming-case-gunmetal-black
https://linustechtips.com/topic/377290-side-fans-pushpull-air/
Hi, I have a Corsair Vengeance case. I have two 120mm fans toward the bottom in front pushing in air. The 120mm at the upper back fan is blowing air out. I also have two 140mm fans on top of the cases blowing air out. I have a question about the two 140mm side fans. They align up to my 2x 980SLI. Should I have them blowing air towards the GPUs or pulling air out? Most of the fans are Noctua
Thank you.
David
I just tried some different configurations on my side fan, I have a different case than you, but I noticed about 3°c lower temps with the side fans exhausting, not a very big difference. It will probably vary for you and if you do go exhaust I would probably flip the rear fan to intake to get more airflow and closer to positive pressure.
The reason I think it runs a little cooler if the side fans are exhausting is that the gpu pulls air from below in the bottom of the case and blows it out towards the side panel
edit: so if they are intake then they are fighting the airflow created by the gpu fans
(unless you've got blower style cards) it helped my cpu temps by about 2°c having them on exhaust as well. (Also negligible)
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5099909
Its best to have it push air into the case but the side is not filtered so its gonna get dusty fast.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5099913
damned double post
60FPS Microwave
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5099918
Thanks for the reply.   I actually bought fan filters that go in front of the fans.  Supposedly they help on dust.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999257
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5099933
Thanks for the reply.   I guess I should run some benchmarks and monitor the GPUs temperatures.
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5099937
Yeah see what works best for you, I'd be curious to see what you end up with so let us know! Also good call on the filters. like the other guy (edit: melting point) said, it'll get messy quick without them
Edit again: if to I'd. Sorry I'm mobile
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5099963
Ok sure, I'll let you know the results.
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-5100019
  • 5 months later...
I know this is digging up an old thread (He's dead, Jim!) but I stumbled on this while looking for a different topic.
The general rule for side fans is: If you have blower style cards put the side fans on intake, this will help feed fresh, cool air to the cards. If you have circulating cooler cards put the side fans on exhaust, this will help suck out the hot air being blown out the side of the cooler directly at the side fans.
Just an FYI.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/377290-side-fans-pushpull-air/#findComment-6463934
