Does anyone know any waterblocks that have red logo or writing in led. Anything except for XSPC?
Example
I'm planning on buying this, and I think its LED is red.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835856022
i7 8086k @ 5.3Ghz / 32GB DDR4 Trident Z RGB @ 3733Mhz / Aorus GTX 1080 11Gbps / PG348Q
Example
If you are talking about custom watercooling blocks any clear acrylic block from EKWB, XSPC is good since you can add or change LED's that light it up.
I am looking for custom one as i am planning to have my custom loop later but for now will only watercool CPU, Thanks for suggestions.
