Sapphire r9 290 tri x XSPC razor waterblock
Solved by FluffyNuggets,
I'd recommend using this http://www.coolingconfigurator.com/newhardware
If it's a reference PCB unmodified then that block should work but may wanna double check to make sure. Always hard to determine with some cards. I looked and was only seeing blocks for that cooler for the 290x.
Featured Topics
Scorpiopt ·
Posted in Troubleshooting0 -
4
ThankGodItsFriday ·
Posted in Programs, Apps and Websites2 -
frostymelts ·
Posted in Troubleshooting3 -
2
RevGAM ·
Posted in Custom Loop and Exotic Cooling8 -
JakubR88 ·
Posted in Power Supplies6 -
2
3
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
