Hello, I'm new to the forums, and I need help building a strong future capable gaming rig. Here's a link to my current PC plan please tell me if their is any way I could get more performance, whilst still able to maintain 144 fps over 3x 144hz monitors.
http://pcpartpicker.com/p/8JFbzy
PLAN:
Intel Core i7-4790K 4.0GHz Quad-Core Processor
Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard
Corsair Vengeance 8GB (1 x 8GB) DDR3-1866 Memory
Sapphire Radeon R9 295X2 8GB Video Card
NZXT H440 Designed by Razer™ ATX Mid Tower Case
Antec 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Microsoft Windows 8.1 (OEM) (64-bit)
(3 x) Acer GN246HL 144Hz 24.0" Monitor
https://linustechtips.com/topic/375438-enough-power/
I feel that the graphics card is not going to pull of 144fps on 3 monitors, especially if they're 1440p :(
Just pointing this out, it's a 1080p monitor. It might be able to run it on lower settings, but I don't really know much about the 295x2.
Written on my Lenovo Z500 T - I5-3230M   Or
My pc :)
https://linustechtips.com/topic/375438-enough-power/#findComment-5077885
http://www.hardocp.com/article/2015/03/16/asus_rog_poseidon_gtx_980_platinum_vs_amd_r9_295x2/1#.VWdMO1XF-R8
R9 290X2 draws 774watts of power on load.   :lol:
GTX 980 only draws 1/2 of that.
Your power supply would burst into flames after killing every component connected to it.  I would just go with a 980.
144fps on all 3 monitors is quite a tall order.
https://linustechtips.com/topic/375438-enough-power/#findComment-5077925
the 980 poseidon is significantly more expensive considoring you'll need to watercool it. the 295x2 (while performing bettter) is already watercooled.
most of the time it needs a little more than 500w. i would calculate with 600 to be safe. the total system would draw 800 then. more if youre gonna overclock which i would recommend. the lepa maxbron 1000w would do the job fine.
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/375438-enough-power/#findComment-5078370
considering the 295x2 draws higher than the standard atx power from each 8pin cable, you're going to need to make damn well sure your power supply is up to snuff. you'll need a high power quality (preferably single rail) power supply. as good as antec is, that power supply won't cut it at all.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/375438-enough-power/#findComment-5081243
