Hello!
I got a bandwidth of 90 mb/s down and up.
But when I download something in chorme is says 250kb/s!
Please help me!
did you try http://www.speedtest.net/? paste the results here.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/375422-chrome-problems/#findComment-5077638
it's working just fine, not everything downloads at your bandwidth's speed, the file which you may be downloading may not download at the same, hence chrome will show lower download speeds, not because of chrome, try downloading the same file over IE to test.
PCPartPicker
https://linustechtips.com/topic/375422-chrome-problems/#findComment-5077660
It's not always the downloadspeed you pay for. Most of the time it depends on the server your downloading from. If they limit the downloadspeed you can't do shit about it.
Intel i7 6700k - MSI Z17A0 Gaming M5 - 4 x 8Gb Kingston HyperX 2666Mhz - MSI GTX 970 - Samsung Pro 128Gb - WD 3Tb - 750 Watt MS-TECH
https://linustechtips.com/topic/375422-chrome-problems/#findComment-5077661
just so you know , that actually a letter from kannada language  http://en.wiktionary.org/wiki/%E0%B2%A0
PCPartPicker
https://linustechtips.com/topic/375422-chrome-problems/#findComment-5077670
