Network Problem - please help
Solved by Dzzope,
You don't have a valid IP address, that is what the release / renew does. so you need to perhaps re-set the adapter (you can disable and enable or try release and renew again or even just do the troubleshoot issues (right-click on network icon in status bar)
It *shouldn't* be your router causing it unless you have a static ip somewhere thats causing a conflict.
DavidPatrascu ·
Posted in General Discussion4 -
1
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
Beenlucky1 ·
Posted in Cooling4 -
Biermax ·
Posted in New Builds and Planning10
play_circle_filled
Latest From ShortCircuit:
